I'm trying to get mkv to play on my ps3, I followed these 2 guides and they both didn't work, my ps3 was unable to detect any files in my usb key which is formatted in fat32
Followed http://www.afterdawn.com/guides/archive/how_to_play_mkv_content_on_playstation_3_ps3.cfm
and http://hubpages.com/hub/How-To-Play-MKV-Files-On-Playstation-3
Tools used were tsmuxer and mkv2vob.
assuming you did everything correctly, at a guess i would say the file is too large. most vob files i have created with mkv2vob usually dont fit on a disk. try burning vob file to a dvd using roxio or nero and burn as data dvd.if it dont fit on a disc then thats the problem.
If I recall you have to go to the options for the usb stick in the ps3 menu and select "display all" ,you should now see your files and if compatible you should be able to play them.
MKV with DTS-HD to PS3
By tge101 in forum AudioReplies: 17Last Post: 21st Apr 2011, 09:50 -
[Help] Blu-Ray > MKV > Hardcoded Vid & Sub > MKV > PS3
By psionicsin in forum Newbie / General discussionsReplies: 2Last Post: 3rd Mar 2011, 02:07 -
How to convert mkv to ps3 viewable format maintaining mkv subs in new file?
By shuyinliquid in forum Video ConversionReplies: 2Last Post: 14th Dec 2009, 01:17 -
MKV to PS3 format help
By badclaw in forum Video ConversionReplies: 4Last Post: 30th Sep 2009, 14:23 -
Another MKV on PS3 question
By mpalm887 in forum Blu-ray RippingReplies: 3Last Post: 22nd Apr 2009, 17:31
