I have recently bought a Daewoo 8000K DVD Player in Spain, which will only play Region 2 DVD's. Can't find a multi-region hack anywhere on the Internet or any mention of this specific player on any website!
Can anyone help?
Type in fast :
RegionFree: "STOP" 44080 (region all)
Region1: "STOP" 44081 (region 1)
Region2: "STOP" 44082 (region 2)
And so on...
The sentens in(...) is shown on the screen when activated... Type it fast, but not to fast :) -
I tried:
- Player switched OFF, no disc, pressing "STOP" key and typing 44080
- Player switched ON, no disc, pressing "STOP" key and typing 44080
- Player switched ON, disc inside, pressing "STOP" key and typing 44080
and that doesn´t work, could you be more specific about that hack?
Regards. -
It sounds like you're doing it right... it had some problems to but you have to type it fast, but not to fast :).... it had to try propably 10 times, so just keep on trying :)
Hi
I also cannot get this to work... I have tried disc in, disc out, tray open and tray closed, but with no luck.
Did anybody actually make this work, if so what precisly do you have to do??
Can anybody HEEEEEELLLPPP.
SONY BDP-S350 how to crack region codes from its own menu?
By madfogs in forum DVD & Blu-ray PlayersReplies: 24Last Post: 26th Aug 2015, 17:00 -
How to change a Daewoo DSL-19M1WC TV/DVD unit from region 2 to multiregion
By gcatano in forum DVD & Blu-ray WritersReplies: 1Last Post: 7th Dec 2011, 01:06 -
Region crack reversal
By Che_qwerty in forum DVD & Blu-ray PlayersReplies: 2Last Post: 21st Jul 2011, 07:48 -
crack region code on avi files to burn to dvd
By wilbureduke in forum Newbie / General discussionsReplies: 3Last Post: 11th May 2010, 21:12 -
daewoo dv-1100a region free hack
By noblegirl in forum DVD & Blu-ray PlayersReplies: 2Last Post: 6th Jun 2009, 18:18
