I bought a Communist Chinese DVD set of Star Trek Voyager,all seven season. I would not buy any other and would recommend you avoid tham also. First their pressed on DVD5's(4.37GB) disks so there no better then you could transode from a U.S. set which is DVD9(dual-layer). In fact there probably worse. My transcoded copies look better. The sound which is said to 5.1 is reported by PowerDVD as 192bit,how can that be 5.1? FYI
Closed Thread
5.1 can have a lower bitrate than 448kbps all the way down to 48kbps.
Chinese subtitles require Chinese font on the computer?
By Haopengyou in forum SubtitleReplies: 0Last Post: 24th Mar 2012, 11:04 -
Retail backup's of TV Series on DVD
By ss30 in forum DVD RippingReplies: 2Last Post: 21st Aug 2008, 05:12 -
replace audio track in retail DVD
By foolosophy in forum AudioReplies: 7Last Post: 2nd Aug 2008, 18:04 -
Can not rip DVD-R disc (not retail)
By NotSoEasy in forum DVD RippingReplies: 47Last Post: 14th Jan 2008, 01:25 -
chinese dvd-r
By superray in forum MediaReplies: 17Last Post: 13th Nov 2007, 16:29
