I have some old MiniDV tapes that I want to capture on to my pc. The tapes were from a pretty new Samsung stanard def camera. I use DVSplit with my current HDV MiniDV tapes that I record with my HV30 and it works great. When I try it with the old tapes there are errors. Some times it doesn't recognize my camera, and when it does it stops short. The camera will play and the video will show up on the camera screen, but not on the preview window in DVSplit. After a few seconds the tape stops and the error message says there was nothing to capture. Other times it will play all the way through and end when the tape is done playing, but the .m2t file will be 0KB. I have the PLAYBACK STD set to auto (i tried forcing DV), 4:3 (tried 16:9), I tried AVtoDV on (dont really know what this is), and DV OUTPUT on HDV/DV and DV LOCK. Has anyone had any success capturing from tapes from other cameras? Or heard anything about it? Also, I'm pretty sure I heard that you can run another camera through the HV30 and capture on to pc. I have an old camera that I would like to do that with. How's this done?
Thanks,
Adam
Also, when DVSplit wouldn't recognize the camera vista tried installing drivers for it and treated it like a webcam or storage device? type thing. When this happened I opened Device Manager and uninstalled the camera drivers, then unplugged the firewire from the pc, turned the camera off, put the camer in 'camera' mode, plugged it back in with DVSplit open, it recognized it, then I put it in Play mode and it seemed to fix that problem. Thought I'd add that in case anyone was having that issue too.
Results 1 to 9 of 9
http://www.kiva.org/about -
Thanks ed.
Is there a program that will convert to a .m2t file? Or is that unnecessary with DV? What is the highest quality output format to use with DV? -
DV format isn't MPeg. It saves all frames with no interframe compression to a 720x480i DV-AVI file format. In frame compression is approximately 5x. 1440x1080i HDV compresses approx 25x to fit the same 25Mb/s bit rate as DV.Originally Posted by assman24
What are your editing plans?Recommends: Kiva.org - Loans that change lives.
The only editing that I would like to do is sometimes taking clips from 2 different tapes and putting them together on one dvd/blu ray.
I used Microsoft Movie Capture or whatever the program is called, I can't remember. It popped up when I plugged in my camera to firewire. It seemed to do okay. Is this just as good, or would WinDV do a better job? I couldn't get it to recognize the camera. -
Now that I've been watching some Vimeo vids I think I may want to eventually do some more editing than just clipping.
You will get the same results transferring DV format using Windows or WinDV. Both use DirectShow and Windows device control. IMO, WinDV is more intuitive.
A DV or HDV format transfer results in the exact same data transferred from the tape to a file on your hard drive. There is no quality loss. DV will go to a DV-AVI file (DV format). HDV will go to a *.m2t file (MPeg2 transport stream). Both can be edited in Vista's Windows Movie Maker but other programs give greater capability such as
Adobe Premiere Elements 4
http://www.adobe.com/products/premiereel/?promoid=121DJGSC_P_US_FP1_PRE_MN&tt=P_US_FP1_PRE_MN
Sony Vegas Movie Studio 9 Platinum
http://www.sonycreativesoftware.com/moviestudiope
ULead Video Studio 11.5 Plus
http://www.ulead.com/vs/Recommends: Kiva.org - Loans that change lives.
Hey Adam -
Are you working on a project for your family business? -
Thanks a lot for all of your help ed, its very much appreciated.
dLee: I'm doing this for my home movies.
Cannot capture HDV with Canon HV30
By ChrisU in forum Capturing and VCRReplies: 49Last Post: 4th Mar 2012, 22:56 -
Canon Rebel xti + Canon HV30 vs. Canon Rebel T2i
By assman24 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 17th Jun 2010, 12:47 -
canon hv30 to cimputer
By gilgeva1 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 29th Apr 2009, 12:54 -
canon hv40 vs hv30/20
By minidv2dvd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 6th Feb 2009, 14:25 -
Canon HV20/HV30
By Tyler2000 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 31st May 2008, 14:43
