http://www.acfmovies.com/board/viewtopic.php?t=31371
I was using this guide and it worked all the way up until when im looking at the subtitles in subtitle creator, like one of the last parts. for some reason around my subtitles there is a box. Do you know how i can get rid of that with subtitle creator? or some other program?
i added a picture so that you can see.
Please don't hijack topics. I moved your post to a new topic.
The box is the sub's background.
In DVDSubEdit there is a box titled Subpic Color/Transparency.
While "p" is selected in the drop down box (as in your picture), move the slider all the way to the left from 15 to 0.
The box will go away, but most likely so will the inside of the sub's text since that's also white and p is the only
white color (of the 4 b,p,e1,e2 colors) in your picture.
It could be that the color of text is assigned to b (yellow in the picture).
Choose b in the drop down box and move the slider to the right.
Does the color of the text become yellow?
help replacing audio on DVD
By fullbohr in forum AudioReplies: 3Last Post: 12th Nov 2009, 20:34 -
Mediacoder - Letter box / Crop to resize to add subtitle ?
By kehn in forum Newbie / General discussionsReplies: 1Last Post: 27th Jun 2009, 12:52 -
Replacing one DVD menu with another?
By ericf in forum Authoring (DVD)Replies: 9Last Post: 1st Jun 2008, 17:55 -
Problem with audio wen replacing subtitle
By daemon22 in forum SubtitleReplies: 0Last Post: 7th Jun 2007, 10:38 -
Very weird problem when replacing subtitle
By daemon22 in forum SubtitleReplies: 0Last Post: 6th May 2007, 08:16
