Hi all, I'm new here.![]()
So I have a problem with the new DVB-S2 format.
I recorded DVB-S2 HD file from one HD channel and I want to do 2 things with it:
First Question: How can I convert it to another format (like MPEG2) ? What software ? I tried Pro Coder, CoreAVC and a lot of softwares but none are working.
Second Question: How can I play DVB-S2 h.264 file on my computer ? VLC, Media Player etc aren't working...
Here is one DVB-S2 video for example.
http://darcyf1.net/tbk/Toto87/20080807_1431_HD2_5.TS
I'm completly lost with that new format.
Thanks in advance.
If you have PowerDVD with AVC/H.264-video support installed (PowerDVDUltra) or WinDVD8 with the same support the you should be able to properly play these ts-files. ffshow together with the Haali-splitte is able to decode this video without chrashing within the media player but it shows frequent blocks in the video and stutters. Generaly you should have a sufficient fast processor (e.g. Core 2 Duo > 2GHz). If you can play the video properly on your system then you can also convert it. There are many guides how to do it. Please use the search function.
Schmendrick -
Ok thanks for the reply.
Where I can found a guide to convert DVB-S2 videos ? Because all I found was for DVB-S video.Originally Posted by Schmendrick
Thanks. -
Search for H.264 to Xvid e.g. or AVC to Xvid, as most videos transmitted by DVB-S2 are AVC/H.264-videos with either MPEG1- AC3- or AAC-audio streams.
I have Avisynth installed and use VirtualDubMod opening the AVC/H.264-video using the "DirectShowSource input method. You can use MediaInfo to determine the offset of the audio to the video stream to maintain synchronity between both streams if you use this time offset value.
Schmendrick
DVB-S/DVB-S2 Satellite Receiver with direct HD,SD/SDI output not HDMI
By rahemeen in forum DVB / IPTVReplies: 1Last Post: 19th May 2011, 05:38 -
Need to batch-convert videos to MP4 using same bitrate as source videos
By BLboy in forum Video ConversionReplies: 7Last Post: 26th Jan 2011, 21:25 -
mkvmerge is not splitting videos to dvd5 size+ rotating videos+resizing
By rocketman122 in forum EditingReplies: 2Last Post: 24th Aug 2010, 08:12 -
Conversion usiing VirtualDub - 720 X 560 videos into 640 X 360 videos
By candyman9999 in forum Video ConversionReplies: 1Last Post: 13th Jan 2009, 22:13 -
Captured dvb-s dvb-t mpeg video to DVD
By tonut in forum Authoring (DVD)Replies: 6Last Post: 7th Sep 2007, 07:02
