    Feb 2007
    Hello guys/girls
    I have worked my ass off in order to find following:
    1. A program that can transfer 3 avi files into DVD.
    2. That use subtitle files .srt.
    3. Program which one can customize an own menu with own text/buttons and background sound.
    Nero Vision is so far the best candidate, although it doesn’t support subtitle files.
    Please give me an advice how to obtain a program within my wishes.
    Belfour
    Nov 2003
    I DON'T KNOW
    I don't use subs, but try TDA . You can put subs in or make your own
    https://www.videohelp.com/tools/TMPGEnc_DVD_Author
    Oct 2007
    My preffered method was to encode & add subs with FAVC using HCEnc with no menu then authoring with TDA. That was untill I got my DIVX Ultra hardware player so I don't encode anymore.
