I've decided to try and get away from using TMPGEnc's internal sharpening filter for reasons of better speed. I've settled on Donald Graft's MSharpen filter as my preferred choice for now because I want to be able to use both VDub & AviSynth as my frameservers and this filter has equivalents for both applications.
Typically, I run the following filters on my source videos in this order:
ConvertToRGB(matrix="PC.601")
Crop
Lanczos4Resize
AddBorders
The cropping is to get rid of any black borders from the source video. The resize is obvious and the add borders is to put back my own custom black borders for the purposes of allowing for CRT screen overscan.
My question is a simple one. Where in amongst those lines would you think is the best place to put the MSharpen line? I know it has to go after the crop, but before resize, before add borders or right at the end? What would produce the best result? Does it make any difference at all?
Crop
Lanczos4Resize
msharpen
AddBorders
Should i use and avisynth script for Dv ?
By smartel in forum Newbie / General discussionsReplies: 0Last Post: 10th Mar 2012, 08:29 -
Need Help with My AviSynth Script
By Enkidu in forum Newbie / General discussionsReplies: 3Last Post: 21st Jan 2011, 21:37 -
Avisynth Script Help
By jamhat in forum Video ConversionReplies: 2Last Post: 29th Nov 2009, 06:13 -
Avisynth script
By daz2712 in forum Video ConversionReplies: 2Last Post: 19th Aug 2009, 11:08 -
avisynth script
By magenta2007 in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 25th Sep 2007, 11:29
