I have a player for my tv that will accept videos in xvid format but will not recognize the mp3 on ac3. I was looking for a way to extract the audio convert to ac3 and the rejoin it with the video. Thanx all.
I reject your reality
and substitute my own.
- Adam Savage -
- Mythbusters - -
Several ways to do this:
An easy way is using vdub, you need ac3 acm codec installed
1) Open up in vdub
2) select video=>direct stream copy
3) audio=>full processing mode
4) audio=>compression , select ac-3 acm codec and configure settings (choose bitrate, but sampling rate has to match the input rate or you have to upsample or downsample)
5) file=>save as avi
cheers -
This script will do it for you. You need to install Avisynth for it to work. See instructions in the first post.
https://forum.videohelp.com/topic326127.html
Poisondeathray's method is easier. -
Thanx for the help
- Adam Savage -
- Mythbusters - -
This works well for single files, is there a way to do a batch encode. I have a show that is 10 seasons that could take a while one at a time. Thanx.
- Adam Savage -
- Mythbusters - -
Which one - Poisondeathray's or mine ?
Or try this:
https://www.videohelp.com/tools/Avi_to_Ac3
MP3 to AC3 Possible?
By skorpinok in forum AudioReplies: 2Last Post: 29th Aug 2011, 13:39 -
MP3 vs AC3
By thezanny in forum AudioReplies: 1Last Post: 9th Mar 2011, 17:50 -
AC3 vs. MP3 at the same bitrate
By wallywalters in forum Video ConversionReplies: 5Last Post: 11th Feb 2011, 10:21 -
mp3 -> ac3
By cL0N31 in forum Newbie / General discussionsReplies: 2Last Post: 3rd Apr 2009, 21:26 -
mp3 to ac3
By volam in forum AudioReplies: 3Last Post: 24th Feb 2008, 06:44
