I have an avi file (uncompresed video+audio) to work with. I need to edit a portion of the audio, to mute or lower the volume or dub it over for that part only. What are some efficient ways to do this with free software? Ideally the software should let me look at the video at the same time.
What I can think of is, demux the audio, split into different segments, then edit the audio parts individually.
Depending on the file types of the video/audio, you can demux or save out the audio as a WAV with VirtualDub or VD Mod and edit with the freeware audio editor Audacity. Then mux it back with the video with VD again and save both in 'Direct stream copy' mode with no losses. I usually leave VD running in the background, ready for the edited audio.
Audacity can accept MP3, WAV, Ogg or AIFF files. To save out as MP3, You need to have Lame MP3 ACM installed.
brighten only a portion of a video?
By magnumpy in forum EditingReplies: 1Last Post: 23rd Dec 2011, 01:00 -
trying to strip audio and save video portion only
By geminidreamer in forum EditingReplies: 3Last Post: 17th Apr 2011, 13:28 -
Hi ! How can I cut a portion from a video,and paste it to another?
By nightshift in forum EditingReplies: 20Last Post: 21st Nov 2010, 01:15 -
Removing more than one portion of a video at once.
By M Bruner in forum EditingReplies: 2Last Post: 21st Nov 2008, 05:17 -
Possible Bad AVI with Missing/Lost Portion of Video
By PedX in forum Newbie / General discussionsReplies: 3Last Post: 17th Oct 2007, 14:18
