Hello,
I'm looking for a simple and straightforward way to convert DVD's to XviD AVI.
The type of XviD quality that I'm aiming for is the quality that you see common in TV episode conversions (i.e., approximately 700MB for an hour (42-minute) episode at roughly 624x352). I don't need to achieve any particular exact file size or resolution, but the idea is a balance between file size and quality/resolution.
I have both a PC and a Mac. As for ripping to .vob, I've used DVD Decrypter on the PC, and Mac the Ripper on the Mac. It's what to use next and how to use it that I need guidance on. I've tried a few things (including some of the tutorials on this site), but haven't found anything that worked extraordinarily well, so I'd really like to know what you all suggest is the easiest way for me to get to point A (DVD) to point B (XviD AVI).
Thank you very much for the help.
My best,
David
PS: I'm also open to abandoning XviD for something else.
AutoGK and FairUse Wizard are two easy programs to try. FUW also has a freeware version.
Batch convert DVD folders easily?
By tomkat2010 in forum Video ConversionReplies: 3Last Post: 6th Mar 2012, 19:10 -
Best/Fastest way to easily convert a dvd (.VOB) to .avi
By xxnonamexx in forum DVD RippingReplies: 21Last Post: 4th Sep 2010, 13:17 -
How to easily convert .ts files to Mpeg2 or DVD
By renzo2000 in forum User guidesReplies: 0Last Post: 25th Aug 2010, 17:03 -
Guide for creating Divx/Xvid DVD Rips Easily on a Mac?
By ehmjay in forum MacReplies: 4Last Post: 7th Oct 2008, 18:03 -
Convert .mkv and VOB to .avi (xvid)
By Numse in forum Newbie / General discussionsReplies: 2Last Post: 16th Sep 2008, 04:07
