    Aug 2008
    Hello...
    I want to take my uncompressed AVID media file (a 6 gigabyte video file, with at least 4 audio tracks), and convert it to an MPEG4. How do I do this?
    Is it possible to export it directly from Avid without having to use an intermediate step like quicktime or sorenson squeeze? If not, what should I use to make this work?
    Thanks for the help!!
    I guess you want a mp4 with mpeg4 video with 4 audio tracks?
    I doubt that you can convert directly to a mp4 with 4 audio tracks in avid. I would convert the video(to h264 video) and audio(to aac audio) separate and them mux to a mp4 using yamb.
    Aug 2008
    Im not sure what mp4 is...but I am not interested in putting this video onto an iphone or blackberry, etc.
    all I want to do is convert my video to mpeg4
    thanks for the fast reply!!
  4. depends on what Avid software you're using
    However pretty much all versions can export to mov and then you can find freeware to convert mov to ipod/iphone compatible files
    all versions come with a quicktime codec, so you don't need quicktime pro
    Sorenson is basically for mpeg2
    Originally Posted by jagabo
