I am trying to get all my DVD's onto my PC and then stream them to my PS3 using the Windows Media Player media server.
The beset way i have found so far is to rip the dvd using dvdshrink and then just rename the file from .vob to.avi. the PS3 will then play it.
However it is still really a .vob (accoring to Gspot Video Identifier) and so abcAVI Tag editor will not allow me to add details to its tag. This means that the PS3 cant group it or anything .
am i doing this the best way and how can i add details to a .vob such as title, year, genre, actors etc.
	Coxroach1 wrote,
 "The beset way i have found so far is to rip the dvd using dvdshrink and then just rename the file from .vob to.avi. the PS3 will then play it."
 Have you actually tried it?
 I'm not sure the PS3 will recognize an .avi extension...
 You might be able to stream the vob directly w/o converting,try it....
 I don't stream with WMP,I use TVersity...
 Use something like XviD4PSP to convert your DVD to a format the PS3 will support,as in PS3/Xbox format... " Who needs Google, my wife knows everything" " Who needs Google, my wife knows everything"
	yeah it does work tried it out last night. Weird I know but it works
	So your'e saying that you changed extension (not convert) from .vob to .avi and "streamed to PS3?
 Or are you just playing it successfully on PC? That does work yes!..
 b/c I can't seem to "stream" a file by only changing a .vob extension to an .avi extension to the PS3,thus far..ummh!" Who needs Google, my wife knows everything"
  Trying to do HD-DVD to BDMV for streaming to a PS3...and have a problemBy trimicada in forum Video Streaming DownloadingReplies: 6Last Post: 4th Oct 2010, 21:11
  Streaming from pc to ps3By Peterrrrr in forum Media Center PC / MediaCentersReplies: 1Last Post: 17th Nov 2008, 12:42
  Copy DVD to ??? for highest quality streaming to PS3 and archivingBy FreeLunch in forum DVD RippingReplies: 2Last Post: 30th Sep 2008, 23:44
  Tired of converting for streaming to my xbox or ps3...hav an idea!By tsantsa in forum Media Center PC / MediaCentersReplies: 21Last Post: 13th Jun 2008, 04:11
  Converting Video for PS3 StreamingBy SPK8000LG in forum Video ConversionReplies: 4Last Post: 6th Feb 2008, 05:35
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
