I want to burn SVCD. I rip using SmartRipper, and then use TMPGEnc to create the mpg2 file, and use Nero to burn the CD. EVERYTHING is working great, except the original DVD is 16:9 and I want to preserve the aspect ratio when I play the SVCD (using black bars at the top and bottom) so it doesn't appear "squished" as it does now because it's playing back as a 4:3 ratio.
Is the setting changes needed in SmartRipper or TMPGEnc??? I tried using the drop down box in TMPGEnc wizard and changed aspect ratio from 4:3 (525 lines) to 16:9 (525 lines) NTSC but no effect after burning with Nero and playing.
Do I use the other "16:9 Display" setting in the TMPGEnc dropdown? Or do I have to do something different in SmartRipper? Other settings need to be changed?
Please explain how I can get the final SVCD to playback 16:9 with black bars on the top and bottom like the original DVD. The setting on my DVD player (changing to widescreen) didn't help either.
Thanks!
Almost no dvd players are able to play anamorphic (S)VCD. Resize instead. Source aspect ratio 16:9, target aspect ratio 4:3.
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 07:18
