Hi,
1) I drag and drop an EyeTV-recorded MPEG-2 file onto FfmpegX. It displays various details, such as the resolution - in this case 544x576.
2) I determine that the pixel ratio for the encoding is 32:17, and that the aspect ratio for the film (after cropping to remove letterboxing) is 2.35:1. So, I choose an output resolution of 1024x432.
3) I choose (1) MPEG-4 to encode and as a container, (2) choose H264 to encode, MPEG-4 as a container, and deselect all video encoding options in the interests of a speedy rendering (these being trial runs). For the same reason audio is not encoded.
4) I click "Encode".
5) I receive an output file in each case that is correctly cropped but not the correct aspect ratio, but rather 576x432 (or something similarly square-ish, and distinctly un-cinematic)
Can someone tell me why this has happened three times so far? I'm sick of wasting hours on pointless encodes…
I can confirm that the display aspect ratio for ffmpeg mpeg4 is off (4:3 instead of 2.35:1), at least for that resolution, but not for H.264 (mencoder or x264). It is a presentation thing, as the file does have the whole 1024x432 resolution video in it, even if displayed at 576x432. However my test H.264 video files were presented in their intended aspect ratio.Originally Posted by SiRGadaBout
I don't know why it happens. I wouldn't rule out a bug in ffmpeg, as mencoder and x264 showed different behaviour.
MPEG Streamclip MPEG-TS to MPEG4/H264 (file size & aspect ratio query)
By Heathy65 in forum Video ConversionReplies: 5Last Post: 4th Apr 2012, 11:31 -
ways to determine the bitrate of your dvd to xvid or h264 encodes
By codemaster in forum DVD RippingReplies: 2Last Post: 21st Sep 2011, 21:25 -
h264 smart render problem
By wentwog in forum EditingReplies: 2Last Post: 18th Aug 2010, 14:26 -
Cropping fails on H264 to H264 encodes
By gtwibell in forum ffmpegX general discussionReplies: 1Last Post: 24th Feb 2009, 12:34 -
H264 HP to BP MPEG4 - best way to convert and best tool to use?
By Cake^^ in forum Video ConversionReplies: 6Last Post: 14th Sep 2008, 15:30
