    Oct 2002
    INdiana
    i have XP pro and when it starts up it has a login windows box with a password. i dont have a pasword set so i clock OK and then it will load windows. how do i set it so it will go to the desktop without the login window?
  2. Aging Slowly Bodyslide's Avatar
    Feb 2002
    A Different Timeline
    USA
    It's a 'security feature' not really needed if you are the only one that accesses your computer. Try this site: http://www.annoyances.org/exec/show/article04-103
  4. Member 1st class
    Aug 2004
    Charlotte
    Another option is to download the tweakui powertoy. Auto login is one of the options.
  5. go into control panel>user accounts. make sure the guest accont is turned off. i have seen your problem happend when guest account is on. happend to me when my guest account was turn on.
    Oct 2002
    INdiana
    when the computer boots up and gets to the point right before the user selection screen, a admin login with password box comes up. when i click OK then it goes to the user selection screen. how do i get rid of admin login screen box?
  7. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    Usually, going ingto user accounts and deleting the ASP.net account will solve your problem.
    Nothing can stop me now, 'cause I don't care anymore.
