I used Gui for DVDAuthor (muxman variant) to author my DVD, and everything's fine. I also wish to add an EXTRAS folder for storing a bunch of files that will only be seen on a PC. I'm placing an autorun.bat and autorun.inf in the root that point to EXTRAS\index.html, so a PC with autorun enabled will load the html automatically (which lists the extra files).
Problem is, ImgBurn is capitalizing all the filenames in the EXTRAS folder, truncating long filenames to 31 characters, and replacing any space characters, # characters, and - characters with underscores. I guess this necessary for UDF?
I'm using ImgBurn 2.4.2.0 (latest) with default values, compiling an ISO, then opening the completed ISO in WinRar to check.
Is there a way to avoid this renaming, and still keep the VIDEO_TS compliant with standard DVD video players? Or should I bite the bullet and rename all my files and their HTML references to be compliant?
Thanks for any help.
Tried that. Loaded VIDEO_TS first, then EXTRAS, then the two autorun files.
It warns me to set the file system to ISO9660 + UDF, and I set the ISO9660 to Level X (219 chars) but it still capitalizes and replaces characters.
Maybe something to do with building an ISO instead of actually burning?
Trouble is, I have a DVD on my desk here that I burned about a month ago with ImgBurn, and the filenames are unaltered. Can't remember what settings I used. -
Originally Posted by spamiaint
Advanced tab
Restrictions
ISO 9660: Character Set: Standard/DOS/ASCII
I guess "DOS" would be all caps, try "Standard".
That's the setting I have, I usually have a "Files" folder of stuff I put on my video DVDs, and the filenames are not changed. -
I did get a usable result with CDBurnerXP, using it's Video DVD Layout function. The files are all caps but the characters didn't get replaced.
Thanks both for the tips, I'll try these out together.
Transfering contents from one DVD to another?
By whatever911 in forum Authoring (DVD)Replies: 3Last Post: 23rd Feb 2012, 11:49 -
Merging the contents of 2 DVD into 1
By txl in forum Authoring (DVD)Replies: 4Last Post: 7th Oct 2008, 08:24 -
how to copy the contents from a scratched vcd
By sumeshkri in forum Authoring (VCD/SVCD)Replies: 36Last Post: 28th Dec 2007, 02:03 -
copy contents from vcd
By sumeshkri in forum Authoring (VCD/SVCD)Replies: 1Last Post: 18th Dec 2007, 00:34 -
Contents of a Video_TS Folder cannot be compressed??? Help?
By DJranman in forum MacReplies: 4Last Post: 19th Sep 2007, 05:08
