    Dec 2005
    Denmark
    Hi
    I use media player classic quiet often, yesterday I reinstailled windows XP and since then I have had this problem with the player:
    When ever I play in fullscreen mode and a new file start from playlist, it goes out of fullscreen mode so I can see my start button and the process-bar, very annoying. Didnt happend with my old installation of win XP.
    Anyone got an idea what could be wrong?
    -IronmonkY
    Edit: I have it's setting for "stay on top" but that doesnt help either.
  2. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Options > Player > (uncheck) "Exit fullscreen at the end of playback", maybe.
    Dec 2005
    Denmark
    nice suggestion all thou mine wasnt checked :S
    I think it might be something in Windows XP causing it.
  4. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Okay, do you have the following set:
    Options > Player:
    - Use the same player for each media file
    - Launch files in fullscreen
    Options > Playback:
    - Auto-zoom: 100%
    Not sure if those will help, either, though.
    Dec 2005
    Denmark
    Options > Player:
    Options > Playback:
    - Auto-zoom: 100%
    Yup tried thoese also but I found out the problem, or at least I solved the problem
    I uninstalled DivX and all it's Cr*P, it had something going in the tray. After I removed that, it works fine now. Yay!
    Thanks for all the help
    -IronmonkY
