Hey, So I've got some questions about my mini DV cam.
Okay it doesnt always turn on when I leave the battery in and turn off the cam... it just gets flat by is self? is it the cam or battery?
Also whats a cheap good gunshot mic that would fit this camera, as I use it for skating and want better sound.
Cheers![]()
Even when a camera is off there is residual power drain. In part for keeping things like the clock ticking over, and simply because no battery holds it's charge indefinitely, and rechargeable tend to drain faster than standard batteries when not in use. Also, repeated charging shortens the battery life of rechargeable batteries, as does the manner in which they are charged. Some batteries need to be fully drained before charging or they develop a memory that sets a false base level. Others survive longer if they are charged regularly and aren't allowed to run down too often. Given the age and design of most mini-DV cameras, yours is probably of the former type.
Read my blog here.
No probs. Something else to consider - using the LCD screen eats through batteries, so use the viewfinder whenever possible. Also, most models will have long life batteries available for them. Check out the accessories for that camera on the web or at a local camera store. You can probably get something with double the life of a standard battery.
Read my blog here.
ohh yeap, kool thanks for the advice, ill check on B&H now
EDIT: also with tapes, I see theres normal Mini DV tapes then Mini DV HD, would that make a improvement on quality much? since my camera isn't HD anyways?
VCR Comparison: JVC SR-W5U vs JVC SR-V101US
By robjv1 in forum RestorationReplies: 18Last Post: 22nd Apr 2021, 04:36 -
JVC HR-S5800U questions
By smartel in forum Newbie / General discussionsReplies: 18Last Post: 28th Jul 2011, 20:52 -
JVC SR-W7U questions
By Cingular in forum Capturing and VCRReplies: 3Last Post: 15th May 2011, 01:56 -
JVC SR-MV55US - Users with Experience with JVC Professional S-VHS/DVD Decks
By Anonymous4 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 21st Aug 2008, 16:23 -
Should I BUY the Canon HG10, JVC GZ HD7 or JVC GR HD1 ??????
By thecuban in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 27th Dec 2007, 13:40
