I got 4 ac3 tracks I need to add but GUI for dvdauthor has only 3, so how can I add another the 4th ac3 track?
	ok cool, I don't fancy about menu, I'm using it and I get stuck on the chapters part, it let me browse for a txt file, what do I type in the txt file to tell the chapter time changes I want?
	Using Rejig?Originally Posted by gameroftheuk
 Its chapter time list is a text file listing the times in frames.
 So that depends on the fps of your video. So this:
 would give you chapters every 5000 frames (i.e. if using PAL at 25 fps, every 200 seconds; if using NTSC 29.976 fps, every 166 seconds).Code:0 5000 10000 15000 20000 25000 30000 35000 40000 45000 50000 55000 60000 65000 70000
 A bit of a drag, but you can read the frame numbers off in many video editors, or calculate them with Excel or similar.
 Note that if you have 23.976 with pulldown, you count the frames after pulldown, at 29.997 fps.
 I generally just have an even spacing as above, maybe add one for the end of the opening credits.
  GUI for dvdauthor - audio too loudBy mrcoolekin in forum Authoring (DVD)Replies: 6Last Post: 15th Oct 2008, 05:25
  GUI for DVDAuthor burning iso to dvd player no menu audioBy opti280 in forum Authoring (DVD)Replies: 13Last Post: 8th May 2008, 21:11
  Looping audio on GUI for DVDauthor menus weird problemBy chewie8008 in forum Authoring (DVD)Replies: 4Last Post: 27th Sep 2007, 10:16
  No Audio on GUI for DVDAuthor DVDBy dennis albright in forum Authoring (DVD)Replies: 15Last Post: 15th Jun 2007, 12:05
  GUI For DVDAuthor (GFD) won't let me add audioBy rail in forum Authoring (DVD)Replies: 9Last Post: 14th Jun 2007, 03:53
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
