I have an Xvid .avi movie that has two audio tracks. One is a dubbed Italian track and the other is the original English. Problem is, the English track is track 2. I can only play it in VLC to watch it in English. How can I eliminate the Italian dub (track 1)?
Here is the info that VLC gives me:
Stream 2:
Codec: mpga
Type: Audio
Sample rate: 48000Hz
Bitrate: 128kb/s
Any help will be greatfully appreciated.
Mark.
If you want to convert your AVI to something else, you may select a different audio track in the Audio tab.
If all you want is elimination of one of the audio tracks, you would be better off with a tool like D-Vision. Extract the video, extract the audio, and mux only the wanted audio back again.
If you have QuickTime Pro, and you don't mind a .mov container, then it is as simple as unchecking a checkbox and saving.
There should be no reason to eliminate the Italian audio track. VLC should allow you to select a different audio track after it starts playing by selecting the Audio option from one of the menu choices (I don't remember which one).
I need to burn it to DVD but it defaults to track 1 which is the Italian track. I do have QT Pro and found the right tab. For those with similar problems, From the Window menu, go to Movie Properties. There you see that the audio track has track 1 checked and track 2 unchecked. Just switch them around and save. I am in the process of saving it right now so, I'll get back to you if it doesn't work.
Thanks to those who answered.
Mark.
Audio track shorter than video track in MPEG Video Wizard DVD?
By xxxyyy in forum EditingReplies: 3Last Post: 30th Jan 2011, 14:24 -
Get audio track from DVD Extra instead of film sound track in VIDEO TS
By Josephine in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2010, 13:25 -
How to select audio track opening multi-track container in avisynth?
By lovyagin in forum Video ConversionReplies: 7Last Post: 23rd Sep 2009, 13:16 -
need to substitute spanish audio track with english track
By rebeltaz in forum AudioReplies: 5Last Post: 26th Dec 2007, 20:12 -
re-encode only video track of Quicktimes but keep audio track untouched
By brennbaer in forum Newbie / General discussionsReplies: 6Last Post: 29th Jul 2007, 09:25
