hi all...
Using DVD2oneX, Is there some way to set a particular movie audio track as the default track?
thanks
when re-authoring in DTOX, you can do a Movie Only backup,
and then select the Main Title of your movie, and then if
that title has more than one track ( audio commentary track, DTS, or
standard) you can select the default track you want to play back
in the backup by de-selecting the other tracks than the one you
want. But that will make the Movie Only backup play ONLY with
that track and that track alone. You won't have anything else to select.
If you are wanting to change the UOP ( User Operand Prohibition) to
make say the DTS track be the default audio track, but still have the ability
to switch to other audio tracks, well, then you are talking about
re-authoring the disc.
For that you'd need DVD Studio Pro, and MTR ( the latest version)."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
Assign default audio and default subpicture streams for movie only backups.
By mattstan in forum DVD RippingReplies: 12Last Post: 11th Sep 2012, 05:59 -
change default aspect ratio without re-encoding?
By boonesmi in forum Video ConversionReplies: 14Last Post: 30th Aug 2012, 11:17 -
Pixelated videos - Is there a way to change the default renderer?
By klischee in forum Software PlayingReplies: 6Last Post: 29th Oct 2010, 18:21 -
Change default tracks in mkv (batch)
By Gabbsmo in forum Newbie / General discussionsReplies: 0Last Post: 24th Apr 2010, 09:58 -
How can I change default audio track with DVD Flick?
By jimdagys in forum Video ConversionReplies: 3Last Post: 8th Feb 2008, 07:16
