My capture card, Osprey-220, is doing something stupid. It's swapping fields in different frames. When I step through captured video in VirtualDub, and then I reach a scene change in the video, there's always a field from the previous scene and a field from the next scene.
My question: can I fix this in VirtualDub? As far as I can tell, the standard filters only allow you to swap fields within a single frame. Anyone know how I can hack it to swap fields across frames?
Results 1 to 1 of 1
Recording 1080i 60 fields/sec vs 1080p 30 frames/sec
By johnnyquid in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 4th Apr 2011, 06:38 -
Stream swapping
By P8tterns in forum Video ConversionReplies: 4Last Post: 20th Jul 2010, 20:01 -
H264: tool for swapping frames without re-encoding?
By fvisagie in forum Video ConversionReplies: 9Last Post: 23rd Feb 2010, 20:52 -
convert fields into 50fps vertical half frames & back
By l.pandit in forum Video ConversionReplies: 3Last Post: 7th Feb 2010, 06:21 -
Swapping MB's - Any Advice?
By acraigl in forum Media Center PC / MediaCentersReplies: 1Last Post: 6th Jul 2008, 11:06
