I just got a Galaxy 3538UEP external HDD configured for Raid 1. It has two Samsung 750GB, 7200rpm HDDs. It took me 20 hours to transfer 400GB of data(400,000 files) over USB 2. My computer is a DELL dual core 2.4, running XP, with 3GB of RAM. The computers HDD was 750GB. Is this normal? I have never worked with Raid 1 before. Thanks in advance.![]()
Nothing to do with Raid1 and all to do with the speed of USB2
USB2 is slower than the old ATA66 spec. And that can depend on the chipset so it may or may not reach full speed.
Plus a lot of small files will take longer than large files when they = the same GBs.
Normal via USB2. If you can go ESata to the EHD that is a much faster transfer rate. -
How do I go ESata to the EHD? The EHD has Firewire and USB 2. The Dell has USB 2 only. What do I need to convert to an ESata transfer? Thanks.
To use eSATA you need to put your drive(s) in an external eSATA enclosure. Many enclosures come with an adaptor that lets you use an internal SATA port to connect to the eSATA device. For example (note the adapter):
http://www.newegg.com/Product/Product.aspx?Item=N82E16817392016
Example with RAID 1 (mirroring):
http://www.newegg.com/Product/Product.aspx?Item=N82E16817422023
Even Firewire will be significantly faster than USB2. Maybe as much as 2x. -
RAID-1 is mirroring, how do you explaing double the risk of losing your data?Originally Posted by KBeee
Keep in mind that RAID mirroring is not a complete replacement for back ups. If you delete a file from the RAID array it's gone from both disks. If the O/S decides to scribble all over the drive or a worm formats your drive both disks are messed up. It's only protection against drive failure.
Crucial M4 64gb raid or no raid?
By Stealth3si in forum ComputerReplies: 7Last Post: 20th Mar 2012, 05:13 -
raid 5 -how to rebuild?
By mysts in forum ComputerReplies: 3Last Post: 15th Nov 2009, 22:23 -
RAID question
By mysts in forum ComputerReplies: 5Last Post: 6th Jul 2009, 16:31 -
Raid 5 to Raid 1
By mysts in forum ComputerReplies: 4Last Post: 14th Mar 2009, 00:36 -
Using Raid 0 for Rendering?
By jaffacaique in forum EditingReplies: 7Last Post: 3rd Aug 2008, 19:32
