I recently purchased a JVC GZ-MG130U. When I backed up the files to my hard drive it produced them in MOV format. I created a DVD with this easily enough, but when I try to watch, edit or reviw these clips on windows media player there is no sound. Can anyone suggest a format which will enable me to watch my clips on windows media player and produce a dvd which i can watch on my Philips dpv520? Also if i need a converter for this can you suggest a suitable one?
I am an absolute newbie at this so any help whould be hugely appreciated.
	Very Novice.
	Please give us MORE MORE MORE information.
 How did you create a dvd? What software?
 What audio settings did you use?
 Do you get audio if you play the mov files?
	To create the DVD I used the software provided with the camera, the programme is called "power cinema NE for everio". I used an option "create DVD" and selected a few backup files from my CPU hard drive which were backup files from the cameras HDD. Like I said earlier this DVD then worked with no problems. The problem is that if i try to preview the backup files on my comp using windows media player, there is no sound. I think this type of file is not fully compatible with WMP. For your info the file type is "Movie Clip (.MOD). Very Novice.
  Formats that will play on DVD player to TVBy humpybong in forum Video ConversionReplies: 5Last Post: 15th Aug 2010, 02:32
  How to convert MP3, MPEG, AVI to Windows Media Formats (algorithm)By Nemo_wf in forum Video ConversionReplies: 0Last Post: 13th May 2010, 07:05
  How do I convert various formats TO a dvd that will play on ANY dvd player?By tinman01 in forum DVD RippingReplies: 11Last Post: 10th May 2009, 13:10
  Windows Media Player plays DVD without soundBy anindyanuri in forum AudioReplies: 6Last Post: 30th Nov 2007, 13:07
  Problem with DVD Playback on Windows Media Player.By Cereal Bawks in forum Newbie / General discussionsReplies: 5Last Post: 29th Jul 2007, 16:11
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
