    Feb 2007
    Does DIKO support CCE SP2.
    I am looking for a program that can encode multiple avi files to DVD with a simple menu. Furthermore, the program must support CCE SP2 as I think it is the best encoder on the market.
    Belfour
  2. Banned
    Freedonia
    DIKO apparently works with HCEnc. I've used both CCE and HCEnc and honestly, I now believe that HCEnc is just as good as CCE. I've used HCEnc to re-encode high def video to lower bit rates because CCE can't be used for that and I've been pleased with the results. Why not just try HCEnc and see if that works OK for you in DIKO?
    Feb 2007
    - removed by user -
    Jun 2005
    Portugal
    You can do like this :
    1) ADD 1 movie
    2) Select CCE SP2 as the encoder
    3) Add the movie to jobs
    4) REPEAT STEP 1 TO 3 FOR EACH MOVIE : 5 MOVIES MAX, IT DOESN'T SUPPORT MENUS FOR MORE ENTRIES
    5) Select :
    - Join Jobs to author them together in a single DVD
    - Select your quality ratio
    - Select Join Menu
    Select DEFS to apply a custom background sound ( can be a MP3 ), and a custom background Image
    You should get a simple menu
    Feb 2007
    Delta 2,
    Does AVI2ISO support more than 1 pass with CCE if one join all jobs?
    Belfour
    Jun 2005
    Portugal
    Delta 2,
    Belfour
    Not yet, however you can get good results adjusting Quality Ratio
    Jobs menu was one of the changes in the new version, you can read the full changelog in the forum of that program
    That is the best way to join different type of movies,
    The other away is like this :
    You can input CD1 and CD2....along with subtitles, and it will join at once and sync them together, and will convert with many passes as you want : max 4
    You can combine that join at once with join jobs
    If you click in the Inputs over a AVI file, the button AVI Frames will be active, and you can get screenshots
    It has more than 1 encoder, not just only CCE SP2, you can make jobs using VSO ConvertxtoDVD encoder
    you must investigate/explore what it can do, and what it cannot, there is many possible options combinations
    Feb 2007
    I added 3 avi files with menu in DIKO. After the transformation to DVD, it said that everything worked out fine, although no iso image was created nor vob files.
    Belfour
