  1. Hi
    I converted my Divx movie to XVCD and the size became 1.73 GB, but I don't now how to Cut, so it can fit in to CD's.
    I tried everything on the guides, but it didn't work.
    How?
  2. ali1, you need to use TMPGEnc - MPEG Tools (under File), goto Cut & Merge, and load your MPG file there using the Add button, then double click on your file, this will open a playback window, there you will select the start and end location of the first part you want.
    Then select a new output filename, and select Video-CD Non-Standard, and press the Run button.
    When it's done, repeat this for the second part of the movie.
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
