When I add some files to my imgburn project they appear in correct order but when I pop the cd into my dvd/divx player they are in a different order. I know the issue that is part of Windows about the first file showing up last but thats not the problem
(example)
https://forum.videohelp.com/topic314043.html?highlight=imgburn%20file%20order
Shouldn't the files show up in the same order on my player as they do in imgburn or am I missing something? It should be noted that the problem does NOT occur if I burn with Nero...... Also is there a way to rename a file in my imgburn project but keep the file name in Windows, also a feature I am used to in Nero. Thanks.
I can't solve your problem, but honestly you gain nothing at all by burning data discs in ImgBurn. I almost always use Nero for this thing because I feel that it's easier to control the output in Nero. I like ImgBurn and it's all I use for making DVDs, but for data discs and audio CDs, you might as well just use Nero. We tell people to use ImgBurn for making DVDs because Nero does weird things with DVD format video, like compressing BUPs and IFOs into the same sector (legal, but incredibly stupid to do), not honoring layer breaks, and so on. But for data discs, there really is no advantage to using ImgBurn.
try
tools->settings->build->sort files by source list order"I'll give you five dollars if you let me throw a rock at you" -
Originally Posted by jman98
(I've never had Nero installed, and burn data DVDs just fine with ImgBurn.) -
Only way to control this is to do:
01 Filename.avi
02 Filename.avi
Or some similar scheme. The OS of the device does whatever it wants.Want my help? Ask here! (not via PM!)
Imgburn auto correct file system doesnt ever complete..
By Highroller in forum Authoring (Blu-ray)Replies: 4Last Post: 12th Oct 2011, 15:46 -
How do make a DVD video disc with an .avi file with ImgBurn?
By DaneClark in forum Authoring (DVD)Replies: 4Last Post: 3rd Jul 2010, 02:08 -
Creating MDS file automatically When ripping to ISO With ImgBurn
By bbanderic in forum Blu-ray RippingReplies: 2Last Post: 2nd Feb 2010, 21:53 -
Why Does ImgBurn Only Sometimes Build an MDS File with ISO File?
By cyberboy in forum Authoring (DVD)Replies: 1Last Post: 13th Aug 2009, 23:36 -
ImgBurn and File Order
By ctdvd in forum MediaReplies: 4Last Post: 28th Sep 2008, 13:32
