Hi All
I am capturing my old VHS tapes, with the help of a dv camera, connected to my pc through firewire.
I am using winDV to capture the DV data.
My problem is, my VCR has only one audio channel, but the data is captured as stereo, so I can only hear sound in one channel (left in my case).
Since I have many avi files, I'd like to do the conversion (drop right audio channel, and create a mono avi) automatically. I was thinking of avidemux, ffmpeg, or mencoder, but I could not find the right way to do that.
Currently I am doing the following
1) save wav file using virtualdub
2) drop right channel, and make the wav mono using Auducity
3) replacing the stereo audio track with the new created mono wav from step 2, using virtualdub again.
I am familiar with both XP, and linux (ubuntu in my case), and I'm also familiar with shell scripts. Is there a tool I can use to do all that in batch ?
thanks,
popo
Results 1 to 1 of 1
trying to extract the 7.1 channels (8 channels) from Blu-ray disc
By billsantos in forum AudioReplies: 2Last Post: 20th Feb 2011, 15:28 -
Capture and Record US Cable Channels in full HD?
By onesikgypo in forum DVB / IPTVReplies: 14Last Post: 2nd Jun 2010, 22:42 -
recording cable HD channels on pc tuner/capture card
By Zipbiscuit in forum DVB / IPTVReplies: 2Last Post: 26th Dec 2009, 09:52 -
ATI 650 capture card: analog channels black&white
By lhughes in forum Capturing and VCRReplies: 2Last Post: 3rd Nov 2009, 06:34 -
capture crypted channels
By Solona in forum DVB / IPTVReplies: 3Last Post: 25th Feb 2009, 16:15
