    Feb 2008
    New Zealand
    Hi,
    Is it possible to extract only the music from audio CD i.e. without the lyrics song.
    If yes, please let me know, which is the best software for that?
    What are the things, we should considered to maintain the quality of the extracted music?
    Thanks,
  2. Member leghorn's Avatar
    Apr 2007
    Germany
    Your request seems a little cryptic. Extract music from CD without the "lyrics song"? What does that mean? Do you mean ripping the tracks without the singing?
    If you want to extract audio tracks from CD, you might want to use ExactAudioCopy. But as far as I know, there's no ripping tool which automatically cuts out the singing. If it's that what you want, you need to rip the track(s) and edit them with an audio editor, e.g. Audacity or Goldwave.
  3. Banned
    Jun 2007
    UNREACHABLE
    [ D E L ]
    Feb 2008
    New Zealand
    Thank you all. I think, the software suggested by DB83 will do the job.
