Hi
Dont know if this is the correct place to ask but here it goes
I have been using staxrip for a little while now ( learning it ) . All went fine (going form DV to mp4 ), incorporated avisynth scripts and filters ( various subtitles etc)
No all of a sudden I can not evenget it to open a file to be processed . it keeps crashing on me saying that the AVIFileGetStream failed. no matter what I tried , reistalling etc included I keepp getting thisproblem now
Also ops up that the aplication DLL c:\windows\system32\rqRjJaxx.dll is not a valid windoes image and have to check againts the instalation diskette. as I dont kno what this dll is related with I have no clue against what diskette that to compare ( actuall dotn have any diskettes )
Please anyone that can help me out, been googlingand readin all over but cant find anything that might give me some help
appreciate your efforts
I was so close to having a settup ready for batching with additions of timers on screen ( avisynth scripst) etc etc
Guy
Greets,
Sorry to hear you are having probs with StaxRip. I have been using it for a little while now and have been very happy with it. Not experienced any of the problems you have mentioned. The only time I crashed StaxRip was when I messed up a filter variable and saved it as part of my default template. So as soon as it auto loaded the template and hit my error it had a prob. That was easy enough to fix. Not heard of the .dll you mentioned - Google did not even show anything for it.
I would suggest that you also ask your question in the Doom9.org forums under the MPEG-4 Encoder GUI section if you cannot find the answers here. StaxRip has some active threads there and he seems very good with keeping up on feedback of his program.
@ Videohelp. My sincere apologies for referencing another vid forum here. Videohelp is a fine site and has provided me with heaps of valuable video info and I greatly respect it. Yet, sometimes one needs to point to other sources for the info needed.
Cheers,
RickRene: Could you not just wound him a little bit?
Hans: Well now, with a 25 pound shell that is not easy.
'Allo 'Allo -
Thanks for the reply
I was very happy with it too , I fanaly managed to get it running again but still it keeps crashing
most errors are AVIFileGetStream failed , vie gone totally barebone as it were and still
if it does load the cli then its virtualdubmod crashing it
aarch
Staxrip. No sound?
By The.King in forum Video ConversionReplies: 2Last Post: 23rd Apr 2012, 13:25 -
StaxRip mastered...
By The.King in forum Video ConversionReplies: 4Last Post: 17th Jun 2010, 14:02 -
StaxRip or Handbrake
By Loader09 in forum Video ConversionReplies: 1Last Post: 22nd Oct 2009, 14:21 -
presets for Staxrip
By greendesert in forum Video ConversionReplies: 0Last Post: 7th Jul 2009, 10:06 -
iPod 5.5 in Staxrip?
By FallenAngelII in forum Video ConversionReplies: 0Last Post: 2nd Sep 2007, 00:55
