    Aug 2008
    So basically I downloaded tons of ktv that are in the mpg format. I was able to demux the files and eventually make it work on the dvd but for some of the ktvs, it gives me an error saying:
    Cause:
    Not a 11172-2 or 13818-2 Video stream
    If this is a capture from TV it may have a missing/wrong header.
    Please go to Tools and try Fix Stream headers on the file.
    When i tried the Fix Stream headers, it said "Nothing was done."
    So does anyone know how to fix this problem so I can get these ktvs onto the dvd.
    You can try demux/repair the mpegs that wont work using projectx and pvastrumento. THen import the streams in dvd-lab pro.
    If it wont work with those you can try videoredo(not free though) using the quick stream fix.
    Aug 2008
    Thank you, I'll give it a try
    Aug 2008
    I just tried the pvastrumento , and when i press demux. I don't know what happened but I think it only gave me the result in .txt file. ?
    Aug 2008
    Okay, I didn't know how to use the other two programs but the videoredo works fine , 15 day trial.
    Then is there another program that is similar to videoredo?
  6. maybe womble's mpeg video wizard, but like videoredo it's not free.
