Hello, can anyone can help me with this:
I have a movie with Russian audio in m2ts format, and i have a dvdrip with Spanish audio which is the audio i want (i'm from México), how is the best way to mix the Spanish audio with the HD video from m2ts file, without lose quality in the HD, and at the same time reduce the size of the video which is 15GB. I don´t care the final format as long as i can play it in my pc.
I can use MAC or PC software by the way.
Thanks in advance for you kind help
Hugo
	woow that was fast thank you very much, is there a way of make the movie smaller in size with no quality loss, thanks again.
 Hugo
	You can reduce the size of the file by encoding to various formats such as Divx/Xvid or H.264/X.264, but you will always lose quality when doing this.
	Other thing, i have a DVDrip in divx, my mistake cause i did not clarify well, i think i can use virtualdub, or i there something better now?
  M2TS File No Audio in Premiere (works fine in VLC)By koberulz in forum AudioReplies: 22Last Post: 6th Oct 2011, 02:46
  mux m2ts to m2ts with AC3 audio without reencoding the videoBy BirdDaddie in forum Video ConversionReplies: 3Last Post: 22nd Aug 2010, 22:19
  some m2ts file audio problemBy alirafaat in forum Blu-ray RippingReplies: 2Last Post: 30th Apr 2009, 05:28
  I have an MKV file, but when I change it to an m2ts file, the AR changes?By anonymous99 in forum Video ConversionReplies: 22Last Post: 19th Jan 2009, 15:24
  edit m2ts file with megui audio errorsBy scorpio1959 in forum Blu-ray RippingReplies: 3Last Post: 29th Apr 2008, 18:11
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
