Ok... I'm using Premiere C3 to cut a film. What is the most subtle way to sync audio and video together. What I mean is so the clapper board is synced to the audio which has been recorded separately...
Anyone know a good program or system to do this in an easy way?!
	If you slated each scene with a clapper-board, go frame-by-frame on the video until you see the frame where the top part of the clapper first touches the bottom, and mark that as a poster frame. On the audio track you will go to the point where you here the snap sound of the clapper and mark that as a poster frame. Align the poster frames of video and audio, and you will have sync. You will cut out the sections with the slate at the front of each scene, so to make sure video and audio tracks remain in sync, you can mark various other points of the clips for alignment. With Premiere timelines, it is quite simple to sync video and audio tracks by matching particular frames to distinctive sounds, even when you don't slate each scene with a clapboard.
 Check out this guide: http://www.mediacollege.com/adobe/premiere/pro/audio/synchronize.html
  synchronizing video and audio in a remuxed MKSBy wsw70 in forum Video ConversionReplies: 0Last Post: 18th Jul 2011, 07:37
  Searching for a synchronizing and video/audio editing softwareBy Raziel in forum EditingReplies: 4Last Post: 2nd Jul 2011, 12:36
  synchronizing an new audio stream on a video fileBy gouletjo in forum Authoring (DVD)Replies: 5Last Post: 15th Feb 2010, 19:47
  Problem synchronizing audio and videoBy weareone in forum Newbie / General discussionsReplies: 11Last Post: 20th Mar 2008, 19:20
  Synchronizing audio/video with FFMPEGBy beyondthegrave in forum EditingReplies: 2Last Post: 13th Nov 2007, 09:32
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
