My machine has 256mb and 12mb on the video card. How can this not be enough? =/
Also, could someone explain regions? Thanks.
Ash
When a program usually "runs out of memory" it means the virtual memory in Windows is down to 0, this can happen usually on Windows95/98 and Me, because they have bad memory managment.
This can also happen when an EXE file goes bad, so first thing I suggest you try is re-installing a fresh copy of Windows, meaning, uninstall what you go and re-install a new version.
Lastly, checking for viruses couldn't hurt either
PS: What do you want to know about regions ?Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Well, as long as the problem is solved, that's the important thing
Best Regards,
Sefy Levy,
Error messages burning data DVD using Nero version 6
By craigsb in forum ComputerReplies: 6Last Post: 27th Oct 2011, 09:12 -
DVD error while burning in NERO 7
By coinsdrop in forum Newbie / General discussionsReplies: 19Last Post: 22nd Apr 2009, 10:46 -
Error, after burning a dvd with nero
By Remyisme in forum Newbie / General discussionsReplies: 13Last Post: 27th Sep 2008, 02:11 -
Memory mapping error
By Illusionist in forum ComputerReplies: 1Last Post: 12th Jul 2008, 22:15 -
NERO gives me error message when burning DVD
By qwazi in forum Authoring (DVD)Replies: 8Last Post: 10th Aug 2007, 01:01
