Results 1 to 9 of 9
  1. Anonymous
    Guest
    7777777
  2. Member DB83's Avatar
    Jul 2007
    What is the soundboard source ? Card on on-board ?
    Obvious suggestion but have you checked the audio mixer settings ?
  3. Anonymous
    Guest
    7777777
  4. Member DB83's Avatar
    Jul 2007
    If it worked before with Vista installed then I doubt whether it's a software issue. But then it's Vista so anything goes.
    But coming back to my previous post. Most onboard (and cards) install an audio mixer panel. Mine is a Realtek and is accessed from an icon in the tray. All outputs have their own settings and it is not unknown for an OS to alter these without any input on your part.
    Better to check this out first before installing another OS.
  5. Anonymous
    Guest
    7777777
  6. Member DB83's Avatar
    Jul 2007
    No mixer panel, all options in the vista sound panel are set to maximum. I really dont want to have to go and buy a seperate sound card and have a big extension cable to plug my headphones into just to get clear audio, but that may be the only solution.
    I would be amazed if Asus did not have a utility for this as part of their driver package.
  7. Anonymous
    Guest
    7777777
  8. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    If you can't find a utility...or need a quick fix until you can figure it out:
    With this mini USB audio card you can easily add sound to your computer or notebook and connect speakers and microphone or even a headset for VoiceOverIP internet telephone calls.
    Special Features
    * Mini USB audio card with speaker output and microphone input
    * Works with Windows XP/200/ME/98 SE
    * No driver installation required
    * Simply connect to the USB port
    * Ideal for Skype
    * Drivers for Windows 98 supplied
    I've got one....my old computer had strange sound issues once.....it works well.
  9. Anonymous
    Guest
    7777777
