Did you press apply?
In windows explorer (or any folder open), tools=>folder options=>file types tab=>select the file type => press change => select the program you want to open with (i.e. VLC) and checkmark the box "always use the selected program" => press ok
You can also configure in winamp to NOT associate those filetypes with winamp (is it .mp4?). Options=>preferences=>file types => unhighlight the file type.
Assign default audio and default subpicture streams for movie only backups.
By mattstan in forum DVD RippingReplies: 12Last Post: 11th Sep 2012, 04:59 -
Default Subtitles?
By lamprey in forum Blu-ray RippingReplies: 7Last Post: 8th Oct 2011, 21:49 -
VlC became default audio player, some how, but I can't default 2 foobar?
By Denvers Dawgs in forum ComputerReplies: 1Last Post: 17th Sep 2011, 17:38 -
Subtitle Creator - Unable to set Default Subtitle Colors & Default Prof
By blue2 in forum Authoring (DVD)Replies: 2Last Post: 15th Nov 2009, 22:47 -
Cx2D default
By tai in forum SubtitleReplies: 0Last Post: 9th Oct 2009, 11:18
