    Aug 2008
    Canada
    Hello,
    Is it possible to edit a XVid avi file in Vegas and save it without having to re-compress the file again ?
    Since it is already compressed, maybe it is possible, but there are so many codec options...
    I edited a 111M file and ended up with a 3G file even after removing a few minutes of footage !
    Thanks.
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Fast recompress in virtualdub should save without reencoding. I don't have vegas so I dont' know what equivalent mode it might have.
    Of course you could always try reencoding back to xvid or divx but there will be some quality loss with a reencode.
  3. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Originally Posted by michelp
    Hello,
    Thanks.
    Vegas will decompress xvid or anything else to the project format you specified under File-New (e.g.DV or uncompressed). Internally it decompresses to RGB whenever you process.
    So, from there, after editing, you can export to any supported format. To return to xvid, you need to install the codec. Vegas doesn't support xvid encoding out of the box.
    http://www.kiva.org/about
  4. If your editing consists of just simple cuts and removal of sections like commercials, you can do it all in vdub for free without re-encoding. If you editing is more complex, has transitions & special effects, you have to re-encode either way
    Aug 2008
    Canada
    Thanks everyone for the hints.
    Will try VirtualDub, since all I need is to remove small parts of file.
    Thanks again,
    Michel
  6. Member Cornucopia's Avatar
    Only if it's on an I-frame.
    P- and B-frames will need re-encoding.
