    Jul 2008
    Hi,
    I want to learn to make documentary type videos. For the price
    range I can work in, it seems the Canon GL2 would be best since
    zoom power will be important.
    What about editting? I want to use a PC, and haven't bought
    the computer yet. What computer speed and memory size etc
    would be required to do basic editing like for a documentary?
    I won't be making attempts to do animation, or playing any
    games. What editing program(s) would be best for the money?
    So far I want to use Windows XP instead of Vista.
    Thanks for any help!
    David
    USA
    nopEda, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
    Try to choose a subject that describes your topic.
    Please do not use topic subjects like Help me!!! or Problems.
    Thanks,
    Moderator redwudz
    And welcome to our forums.
    Jan 2007
    Republic of Texas
    Think about the finished product first, and then work your way backwards. Is your final output DVD, television broadcast, webstreaming -- what? You will need to look for editing and authoring software that will fulfill the final goal. Then check the system requirements for that software, so that you will have the proper computer hardware to use it. The selection of camera should be made with this in mind also. Will your finished product need to be standard definition or HDTV? Will the video aspect ratio need to be 4:3 or 16:9? If you shoot standard DV, virtually every computer and video editing program will handle it, but if you shoot a high-definition format, you will need to make sure all hardware and software work well with each other. There are also peripherals to consider, such as sound recording, location lighting, etc.
    Once you identify your final output objective, it will become easier to hone down what you will actually need within the budget you have. It is difficult to help you when you are so vague.
  4. Member Soopafresh's Avatar
    Jan 2004
    The camera is only the beginning in the expenses you will face.
    Tripods/Stabilizers = $
    Extra Batteries = $
    Microphones = $
    The accessories will end up costing more than the camera.
  5. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Listen to filmboss80 and Soopafresh.
    It seems you lack any training or experience? I suggest a basic video-film class at local college. You need to master the basics first. Learn on their equipment then you will know what to buy.
    Also, what do you mean by "zoom power will be important"?
    http://www.kiva.org/about
