Hello,
I need a recommendation for software to get my digital video tapes to DVD. I have been using My DVD, version 4.5.2 but it has become unstable. I am able to capture the video but unable to burn to a DVD.
Let me say up front, I am a beginner and have read these forums for some time and to be honest with you, most of you are way advanced for me. I don't want to get as involved as some of you in this hobby. I just want to get my camcorder videos onto DVD. It would be nice to be able to do some basic editing, such as deleting unwanted footage, but past that point anything else would be overkill. Since I have limited knowledge and desire I lean towards the suite type of software such as My DVD which will capture and burn the videos. I know that lots of folks have trouble with this particular software so I think I need to move on to something more stable. It just has to be simple and easy to use and require little technical expertise.
I know that each of you went through the stage were I am at now and had the same needs that I now have. It would be greatly appreciated if you would share your thoughts on what software would best fit my needs.
Thanks in advance for your help.
Is there any software recommend to handle TS in the following way?
By ihmcjacky in forum Video ConversionReplies: 11Last Post: 2nd Dec 2010, 13:29 -
can you recommend good ripping software ?
By Bansaw in forum DVD RippingReplies: 2Last Post: 14th Sep 2010, 18:39 -
Recommend a software for M2TS
By vid2me in forum Video ConversionReplies: 4Last Post: 26th Aug 2010, 15:30 -
Can anyone recommend a freeware screenwriting software?
By rijir2001 in forum Off topicReplies: 0Last Post: 25th Nov 2009, 23:44 -
Recommend burning software other than Nero
By majax79 in forum Newbie / General discussionsReplies: 23Last Post: 30th Oct 2007, 15:30
