Is a good DVD-rip better quality than original VHS movie? What is the bitrate of VHS movies?
are you talking about divx or just a DVD that been put in DVD shrink.
DivX will probably look better if it is encoded at a high bitrate and the resolution is 640x480.VHS has a resolution equal to 320x240(VCD).
You will also have a cleaner picture converting a digital source to DivX instead of capturing a analog VHS source. -
Of course a divx file can contain the 5.1 audio if it has it. Something no vhs copy ever has - dolby pro logic being the best you can hope for.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
It fully depends on the sources and recording quality. File formatting itself is completely meaningless.
VHS isn't 320x240, which is less than VCD resolution, that's a a misunderstanding of a myth created by VCD advocates to make VCDs seem better than they are. VCD is 352x240 progressive. VHS ranges from 250x480 to 300x480 interlaced. Even the best quality VCD isn't as good as a EP VHS recording on good tape recorded with a good VCR.Originally Posted by MOVIEGEEK
newbie want to rip some vhs into DVD
By bambam in forum Capturing and VCRReplies: 5Last Post: 1st Jan 2011, 02:35 -
BD / DVD Digital Video Quality as compared to Uncompressed RAW video.
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 5th Dec 2010, 08:11 -
How do I rip a dvd made on a VHS-DVD recorder?
By dvruser in forum Newbie / General discussionsReplies: 6Last Post: 29th Jan 2010, 12:19 -
X264 DVD rips look very pixelated compared to MPEG-2 i.e. DVDSrink
By Z.Sath in forum Newbie / General discussionsReplies: 19Last Post: 28th Feb 2009, 22:52 -
DVDlab Compared with TDA
By loster in forum Authoring (DVD)Replies: 7Last Post: 30th Dec 2007, 19:34
