I know it is a 2.80GHZ/1M/533 CPU, Northwood or Prescot not known. I have experience with the Northwood CPU and it has been extremely reliable. I am considering buying the P4 2.8g, however I think it may be a Prescot CPU .... are they as reliable as the Northwood ???
Prescotts have an 800 MHz FSP and run much hotter than Northwoods. 533 MHz FSB is a Northwood. I'm pretty sure the 2.8 GHz Northwood doesn't have hyperthreading. And it doesn't have SSE3 which was introduced with Prescott.
The CPU I am considering is the PENTIUM 4 2.80GHZ/1M/533 SL7E2, I am trying to establish whether it is a Northwood or a Prescott. I have searched Intel and many more sites, have found the spec's but unable to establish Northwood or Prescott.
Also, if it does turn out to be a Prescott, are there any known issues I have to think about. -
I have just established it is a Prescott CPU, 478 pin but a smaller chip than the Northwood. Is this a problem for a M/B that has a Northwood 478 pin installed.
The motherboard must also support the higher power requirements of the Prescott and you'll need a bigger CPU cooler to keep it cool.
http://processorfinder.intel.com/details.aspx?sSpec=SL7E2 -
Thanks to those who made comments, I have decided to stick to the Northwood.
In my case the fastest I could go was 2.6 Northwood.
You might be able to find one out there, but they're hard to find
Is a 2.8 Pentium 4 w/HT able to playback HD?
By GLE3 in forum ComputerReplies: 2Last Post: 25th Mar 2009, 10:36 -
Going from amd 9850 to pentium 9550
By johns0 in forum ComputerReplies: 1Last Post: 23rd Sep 2008, 23:30 -
Performace...Pentium D to Core 2 Duo
By ron spencer in forum ComputerReplies: 14Last Post: 31st Mar 2008, 17:42 -
3.4 Pentium 4 or 935 Pentium D?
By DarrellS in forum ComputerReplies: 6Last Post: 11th Jan 2008, 23:58 -
GIGABYTE motherboard / Intel Pentium D 935
By thebirdf in forum ComputerReplies: 4Last Post: 2nd Nov 2007, 13:50
