Hi i just bought a Apple TV, but i cant figure out how to convert my downloaded AVIs to a file format that is supported by iTunes. I tried to use FFMpegX, but when i select a input file (AVI) after pushing the convert button it says it is done, butno converting has been done.
Can anyone help me with som tips how to get my avi-movies into the format supported by itunes (which format is that?)
Results 1 to 10 of 10
I installed Pernian, but when i select source, i choose the avi movie i want to convert, but it says no valid source? Any idea of what i can do?
HandBrake converts video from DVD (MPEG-2) to MPEG-4, so it won't be of much use for AVI source files.
What are the video codec and audio codec of your AVI? When in doubt, try MediaInfo Mac.
As for target format, you should aim for H.264 video with AAC-LC audio in .mp4 format. -
If you want to hardsub movies for the AppleTV, the best thing I've seen is Submerge ($9). The same company makes Road Movie ($20) which adds batch encoding and both take advantage of Turbo H.264.
They cost money, but if you do a lot of subtitle encoding, this will work for you. -
I'm re-hashing a post from a few weeks ago as to steps I would take:
A movie to Ipod freindly video with subtitles
Substitute VLC for DVD Player
Play the .avi file in this app, and have iShowU "hijack"it.
the remaining steps are the sameto mp4."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
CD ripping (not vids, but tunes)...
By cwb in forum DVD RippingReplies: 13Last Post: 9th Sep 2011, 08:46 -
Should I download I-Tunes 10.4.1
By Tom in HD in forum MacReplies: 2Last Post: 2nd Sep 2011, 23:46 -
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 17:30 -
I-Tunes crashes every time I try to play something :(
By Akhet in forum ComputerReplies: 4Last Post: 8th Dec 2009, 17:59 -
How to copy a CD w/tons of mp3 tunes to another CD??
By rbatty11 in forum AudioReplies: 6Last Post: 19th Jun 2007, 19:30
