I am trying to alter one of Pinoy's or Sefy's templates for the XVCD format, because my DVD player will only allow up to 2500 kbits. I believe their templates are set at 3000 max. Everytime I go into change the value and save it under a different name it reverts back to the default of 3000.
I don't know about Pinoy's, but my Template isn't set that high, I edited all of them to make sure it's 1150kbps, if you are using new TMPGEnc 2.51, it has a bug in it, and it defaults all VBR to I think it was 2000kbps.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Obviously, I overlooked your text file in your template package. I now see why this template, Pinoy's and Antonio's templates will not work. I have TMPGnce 2.5.
It is always recommanded to keep an earlier version, especialy for cases like this, i've got TMPGEnc 12a/2.02/2.51 Plus on my system.
Best Regards,
Sefy Levy,
"Alter Detected Properties" in multiAVCHD
By bmccollum in forum Authoring (Blu-ray)Replies: 2Last Post: 19th Oct 2010, 13:54 -
Does half d1 alter file size at all or is it just how the bitrate is used?
By yoda313 in forum Video ConversionReplies: 14Last Post: 17th Oct 2010, 19:28 -
How do I alter a VRO file so Windows Movie Maker will allow me to edit
By povie in forum Newbie / General discussionsReplies: 7Last Post: 7th Oct 2009, 17:27 -
Printing Template
By mleb33 in forum Newbie / General discussionsReplies: 0Last Post: 29th Sep 2007, 08:09 -
How to alter frame size?
By elite123 in forum Newbie / General discussionsReplies: 4Last Post: 20th Aug 2007, 18:43
