Hi,
I am trying to create a simple movie clip using Movie Maker 6.0 that comes with Vista. I can import the videos and pics. But when I drag them to storyboard or timeline...nothing happens. Items don't move to the storyboard or timeline. Copy paste doesn't work either.
Pls help
Results 1 to 9 of 9
None of mine have done that. What format is this file?
http://www.kiva.org/about -
I have tried everything. jpg, bmp. Even videos don't work. I have searched on this issue a lot. Many people have this issue. I don't know if I need to reinstall movie maker. if I do, does someone know how to do it ?
http://www.vistaheads.com/forums/microsoft-public-windows-vista-music-pictures-video/5...toryboard.html
http://forums.techarena.in/vista-music-video/654640.htm
thnx -
My problem is similar to this. I can import MP3 to the Moviemaker but when I drag them to the timeline, all I get are little red x. Maybe DRM? I'm using Vista Premium.
While I rarely use WMM in Vista, I haven't noticed that problem. I just tried it with a Xvid and was able to drag the video to the storyboard and play it back. The red 'X' usually means the format isn't compatible with WMM. I can't open VOBs for one. But if I convert them to MPEG format, they open fine. One way to check compatibility is if they play back on Windows Media Player, they should open in WMM. I can play Xvids with WMP.
edDV seems to have the right idea.
Can you post a Gspot screenshot of one of the problem videos?
This is from the Xvid that works. It also has VBR audio, which may cause problems.
I haven't added any. But I have not installed any updates from windows either. May be thats the issue.
Invest! Use Ulead VS or some other good product. You get what you pay for.
Windows Movie Maker (Vista) and "clips"
By freshone in forum Newbie / General discussionsReplies: 1Last Post: 31st Mar 2009, 16:26 -
Microsoft Vista Movie Maker gives best DVD quality
By quickfamily in forum Newbie / General discussionsReplies: 6Last Post: 26th Jan 2009, 15:06 -
Advancing/Rewinding Clip Frame by Frame on Windows Movie Maker (Vista)
By ione in forum EditingReplies: 20Last Post: 9th Sep 2008, 22:53 -
vista dvd maker
By benny28 in forum Authoring (DVD)Replies: 8Last Post: 16th Apr 2008, 16:15 -
Vista Movie Maker and DVD Maker problems
By steve7510 in forum Newbie / General discussionsReplies: 5Last Post: 9th Jun 2007, 22:18
