Hi guys,
I'm using iuVCR ver 4.15 to capture via vhs;
I am using only composite connectors (yellow / red / white)
so far it works brilliantly, however when loaded it tries to "Begin TV-Tuner initialization" and it takes quite a while.
Is there a way to switch this option off? The most I've figured out is that when you're scheduling a particular task to records on its own, there's an option "DON'T INIT TV TUNER"; but I can't seem to find it in the normal options to have it always switched off...
L
Results 1 to 1 of 1
iuvcr substitute
By marcolisi in forum Capturing and VCRReplies: 1Last Post: 4th Aug 2010, 13:50 -
Getting a strange error in iuVCR now out of nowhere .. !
By ahmadka in forum Capturing and VCRReplies: 1Last Post: 23rd Jul 2010, 08:51 -
iuvcr problems....
By Coluph in forum Capturing and VCRReplies: 8Last Post: 29th Nov 2009, 13:01 -
Capturing help.
By fuseek in forum Capturing and VCRReplies: 0Last Post: 6th May 2008, 09:49 -
Capturing In iUVCR
By MosThaTeD in forum Capturing and VCRReplies: 0Last Post: 22nd Dec 2007, 19:15
