Hi guys,
The past couple of months I have been using Total Video Converter to convert my video's to any kind of format with subtitles, but few days ago my pc crashed. I had to reinstall Windows XP on my machine and I have also installed K Lite Mega Codec Pack. After that I installed Total Video Converter 3.12 (registered version). Now when I try to convert my video to a format (no matter which format) with subtitles I get this message:
Failed to add video hook function: Subtitlehook -f D:\ ....
When I press ok then TVC does start converting but without subtitles![]()
I am absolutely not familiar with the technical side of these kind of things (you are talking to big noob), but because TVC used to work like a gem for me I am trying to understand what went wrong![]()
Can someone explain in easy words what I have done wrong that is causing this problem? If the problem is too complicated can someone tell me a software that is like Total Video Converter (a programm that converts any type of video data to any kind of format with subs). I have noticed that Super is a favorite software of many people, but as far as I know there isn't an option to add subtitles![]()
Thanks in advance![]()
You could try xvid4psp, it supports most input formats and you can convert to many formats and you can add subtitles.
Or else try contact effectmatrix, http://www.effectmatrix.com/forum -
Thank you Baldrick for mentioning Xvid4psp.
It took me a few days to figure out how things work, but now I know which settings to use I must say that Xvid4psp is a really good programm/ software. Output results are very good and encoding doesn't take too much time (1 or 1.5 hour). Now lets hope everything keeps working like this for a long time. Thank you again
Avisynth function to TBC old VHS video?
By Asterra in forum Capturing and VCRReplies: 4Last Post: 4th Sep 2011, 03:35 -
add subs failed.
By izzykatz in forum SubtitleReplies: 2Last Post: 2nd Jan 2011, 17:52 -
AviSynth function to add SUP subtitles?
By MilesAhead in forum SubtitleReplies: 11Last Post: 3rd Feb 2010, 14:16 -
Trying to hook up Component to Composite video
By Airliban in forum Media Center PC / MediaCentersReplies: 8Last Post: 28th May 2008, 22:04 -
S-video hook up yields B & W picture
By dzachau in forum Newbie / General discussionsReplies: 7Last Post: 12th Jun 2007, 20:55
