Hi I have done the region free code to make the DVD recorder region free and I put in a region 1 disk but it still wont play it, is there anything I have to do to make it work ? I have turned it off and turned it back on and its still not playing.
Cheers Shane
Sounds like the region hack didn't work. As an alternative to messing with you DVD unit, you could just make a region-free back-up DVD using DVDFab HD Decrypter.
It said congratulations you are now region free and I have tried about 3 region one disks and its still not doing it, this is what I have been previously doing just ripping them and burning them to dvd again so I just wanted to try and save myself time so it will just play it.
Cheers Shane
Hack working for Sony BDP-S380 region 1, to make it region free?
By Julieso in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Dec 2011, 17:12 -
Region 1 Samsung dvd-vr375 to switch to region free
By catleo in forum DVD & Blu-ray PlayersReplies: 3Last Post: 27th Dec 2011, 11:25 -
Klipsch CS-500, need to make region free / code free / zone free
By Trialsman in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Nov 2008, 14:16 -
Sony DVP-FX720 region restriction - using DivX waiting for region free code
By wig in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Aug 2008, 05:34 -
How to Make a Pioneer DVR-520H Region 1 a Region Free player?
By Ossocao in forum DVD & Blu-ray RecordersReplies: 3Last Post: 26th May 2007, 22:35
