Hi,
I recently made snapshot of different frames in Virtualdub using the snapshot frame function, I saved each bad frame from the video in BMP format, and edited them with Gimp (correcting the errors in pictures), so now I want to paste each frame (BMP) on my video, is it possible ? How ?
If we can do that with another software like Avidemux for example I'm interrested, the frames are in BMP and the resolution is the same, so I think it's possible to put the corrected bmp frames to the video, replacing the bad frames one by one ...
Please tell me we can do that, thanks![]()
I've used this Logo filter http://neuron2.net/logo/logo.html with VirtualDub, and added each stream as a full logo.
how to insert an i-frame in AVIDEMUX2
By shparekh in forum Video ConversionReplies: 5Last Post: 24th Aug 2011, 06:39 -
VirtualDub filter to insert video from another source into a corner?
By Riothamus in forum EditingReplies: 2Last Post: 6th Jun 2011, 07:51 -
Can't insert a source file into Eac3to and More GUI v.1.10.01
By mahogany in forum Newbie / General discussionsReplies: 0Last Post: 3rd Aug 2010, 17:48 -
Snappy Video Snapshot Inner Workings / High Quality Frame Grabs
By acid_burn in forum Capturing and VCRReplies: 2Last Post: 6th Mar 2008, 00:11 -
Insert blank frames at end of video
By kidcash in forum EditingReplies: 5Last Post: 28th Jan 2008, 04:52
