There is an open source project called GraphStudio that is a replacement for GraphEdit.
Find the forum here:
http://forum.doom9.org/showthread.php?t=133928
You may need to install XMMLITE if it is not on your PC:
http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=d7b5dc81-ad14-...5-8c4a9aab5992
GraphStudio:
http://blog.monogram.sk/janos/download/dl-graphstudio.php
RadScorpion the creator of GraphStudio is looking to add a performance measurement tool to test the codec/filters.
Here is the initial screen shot.
A nice addition to GraphStudio is a program called CodecInstaller.
https://www.videohelp.com/tools/CodecInstaller
CodecInstaller is a Windows program that detects the Audio and Video codecs installed on your system, analyzes files to understand which codecs they require and suggests you to install them. This program can be used to analyze files: it supports avi, mpeg, wmv, wma, ogg, flac, mpc, mp3, mp4, wav, wx and will show technical data such as width/height and ratio, length, video codec, framerate, size, bitrate, total frames, quality factor and metadata such as title, album, year (if available).
GraphStudio -> Avisynth -> GraphStudio again?
By elmuz in forum Video ConversionReplies: 22Last Post: 13th Jan 2011, 03:34 -
Capture settings with GraphEdit / GraphStudio
By CaZeek in forum Capturing and VCRReplies: 10Last Post: 15th Oct 2010, 06:46 -
What's the best Open Source equivalent to Nero?
By OM2 in forum Newbie / General discussionsReplies: 7Last Post: 1st Feb 2009, 15:39 -
A proposal for Open Source HD-DVD
By hddvdrebel in forum DVD & Blu-ray PlayersReplies: 8Last Post: 27th Mar 2008, 22:12 -
Quicktime Can't open files after 10.4.10 update
By willrob in forum MacReplies: 8Last Post: 24th Jun 2007, 00:13
